Search In
  • More options...
Find results that contain...
Find results in...
Crashes since I put my 3080 in system. Need help!
I got my 3080 yesterday and it works fine for the most part. My system randomly crashes when I load into a game or play for a while. During Benchmarks and Stress Tests nothing happens. I suspect the PSU isn't enough even tho it should be, right ?
Specs:
- Ryzen 9 5900x 4.00 Ghz
- MSI RTX Suprim X 3080
- ASUS ROG STRIX X570-E Gaming
- G.Skill Trident Z RGB 3200 Mhz
- MSI MAG CORELIQUID 360R
- WD BLUE NVME 500 Gb
- Samsung Evo 850 SSD 500 Gb
- Toshiba 3 TB HDD
- Corsair HX 750
- 2x 140 Fractal Design Fans (Came with Case)
- 1x 120 Fractal Design Fan (Came with Case)
- Fractal Design R6
I really hope someone can help me fix this.
Did you use ddu for clean driver installation?
I would also try 3x cables from psu as those splitters can be tricky.
And how old is that psu?
Yes I used DDU. I had a Palit 1060 in before that.
I am using 3 cables from the PSU.
About 2 years. Its fairly new.
Thanks for your comment mate 🙂
i know it sounds stupid but when you put your 1060 back does it still crash? i dont know maybe the 3080 bricked something
i suggest using DDU and reinstalling windows and i mean a clean install and also reinstall the games if possible
No, because the 1060 didnt nearly draw as much power. I really think its just bricking the trip protector of the psu.
Used DDU and i might try a clean install of Windows. Can't redownload the games tho. My Internet is really bad.
