Search In
  • More options...
Find results that contain...
Find results in...
is there a way to convert a zfs drive into ntfs with window ?
Go to solution Solved by Electronics Wizardy,
You can just delete the partitions on the drive and make a new ntfs partition.
I have an old hard drive that I want to reuse as a game storage but it is a ZFS from a linux machine. I don't really care about the drive content. So, If there is a software that I can use or a way to factory reset the drive I will very much appreciate it
