Random reboots w/o image and VGA led on at the mobo
I found the origin of the problem: it was a mining virus; "Gpu_update.exe". It uses your GPU when idle or with low use. The thing is: the windows task manager doesn't shows its workload in the "3d" graph under the "GPU" tab, it shows it in the "Compute X" graph, that isn't exhibited by default. That's why the HWinfo and later the Afterburner and AMD software were showing the GPU under heavy load and huge temps and I couldn't see anything in WTM, it was not a problem with the sensors of the GPU. Probably the random pc reboots were related with overheating. It took me some time to find out because the virus probably halts when it sees the GPU is being requested by something else. Once I only played a very undemanding game the last few days, and it were stuttering out of nowhere for no reason, all the time, I got mad and started further investigation. After I suspected that it could be such kind of virus (never heard of this kind of virus before, jezz...) I simply took the Ethernet cable off and waited: the GPU loads went to zero after a few seconds.
