i7-8700k 4.3GHz stuck
Solved by unclewebb,
Try using the Windows Balanced power plan. Reset this to default settings. This will allow your CPU to slow down when lightly loaded if that is what you want it to do.
If this does not work, open the Task Manager and find out what is running on your computer. Post a screenshot of the Details tab.
Los_Jackal ·
Posted in Storage Devices3 -
TurboTrym ·
Posted in Programs, Apps and Websites1 -
Pepegovich ·
Posted in Troubleshooting0 -
7
Crystalized King ·
Posted in Graphics Cards2 -
6
Fluuwu ·
Posted in CPUs, Motherboards, and Memory4 -
2
14
