Corsair K55 RGB still working without iCue?
FRD
After troubleshooting of iCue not detecting my keyboard (a common problem with this board), I finally got it to work today.
Before the software was working, I used to change the RGB using the Fn + number keys to change the lights.
Now that the software is installed, I can only change it through the software and the Fn + number keys don't do anything anymore.
I'm wondering. Is it still possible to change the RGB the old way (with the Fn key)? Or am I stuck to iCue now unless I uninstall the software?
I had hoped both would work, since pressing buttons is faster than opening the software or changing profiles every time.
If you could change it before the software, it has onboard memory profiles. Just exit the software and prevent it running at startup. It should revert back to using only onboard profile storage.
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
Pretty logical actually, thanks. Just unfortunately no workaround I think for using both software and button commands at the same time.
I had the same problem with my K70 RGB. The iCue software just made me angry, so I installed 3 profiles that I liked on the keyboard then never ran the software again.
Primary Gaming Rig:
HTPC/Gaming Rig:
I just installed iCue because I thought it would be cool to make profiles, nothing else. In the end it doesn't seem as handy as I thought it would be.
I will probably also make a few profiles that I switch from occasionally. Since I'm fairly new with it. How to switch the profiles fast/easily? Is it also possible in-game?
