Found an old TV tuner card.
I found my old ASUS/VIXS combo 210E card and was wondering if anyone found a way to get this thing to work in windows 10. Sadly the hard drive for the PC it was in was repurposed for other projects, so I won't be able to grab the old drivers from there. The only places with possible drivers I found were http://www.ascendtech.us/asus-combo-210e-pci-e-tv-tuner-card_i_tvcas6008162r.aspx  and https://www.asus.com/supportonly/ASUS TV TUNER CARD(NTSC)/HelpDesk/   but neither drivers seams to work.
Darn, was hoping someone had done some work on it, i forgot to mention there is a video on YT that show how to get the card working with NextPVR in windows 10 but the card should be able to do more.
What program are you trying to make it functional with?
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
Mostly just trying to get all the outputs into one program. so I can see the s-video in as well as the cat5 and FM. I don't care so much for the analog over air video though. also toying around with it to see if i can get it to work like a SDR (Software Defined Radio) tuner
I watched a bit of this video, and it seems Windows 10 will grab the correct drivers for you, but you have to "check for updates" manually, not use the device manager's "update driver" dialog. Worth a shot I'd say. The author didn't specify HOW it showed up, so maybe it'll show up in the "optional drivers" sub-menu.
Primary Gaming Rig:
HTPC/Gaming Rig:
I have tried that method, it seams to only get the ntfc/atsc output working :<
That's odd. I saw quite a few comments on said video about getting the capture functionality working with no hassle. Here's the top comment:
"I got one of these on eBay in September 2018, probably one of the best $11 PC hardware purchases I've ever made. I put it in my motherboard and it was seen by OBS Studio with no extra drivers or anything on Windows 10. Digitized almost 200 VHS and 8mm tapes with this card."
Primary Gaming Rig:
HTPC/Gaming Rig:
