Faulty iMac LCD proximity sensor
Solved by Vojoor,
Okay, this may sound like a bad joke but after having tried everything Software side possible I went on to literally hit the screen with my palm and after just a second or two I saw the temp drop to a normal value, fans stopping and kernel_task drop to 1%… I can’t believe it
kacper6768 ·
Posted in Displays1 -
Minuto ·
Posted in Troubleshooting0 -
Williamgame08 ·
Posted in Power Supplies0 -
1
RagePoweredGamer ·
Posted in Troubleshooting11 -
14
Cookiey ·
brau508 ·
Posted in Troubleshooting1 -
Syponj ·
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
