Friend wanting to Building a PC for Coding
15 minutes ago, FlexHosting said:16GB TridentZ NEO 3600MHZ premium memory
Silverstone PF360 360MM AIO Water Cooler (ARGB)
Arctic Silver 5 Thermal Paste on CPU and GPU
Modified NZXT Watercooler case illumination
Corsair AX850 power supply with all cables
NZXT Sentry LCD Fan Controller
MSI H110M Gaming motherboard
Gainward Golden Sample 550ti
Intel Core i5 6400 CPU
You have a shit motherboard with a shit chipset that limits the maximum ddr4 memory frequency - officially the board supports maximum 2133 Mhz memory.
You have a lightweight CPU that has a 65w TDP rating, and which officially supports DDR4 up to 1866 Mhz. Unofficially, it will probably do 2133 Mhz or 2400 Mhz - IF the motherboard and chipset limitations allow it.
The water cooling is ridiculous overkill for a processor that can be cooled by a 30$ air cooler just fine.
Arctic Silver 5 thermal paste on cpu and gpu - yeah, like it makes 1 degree celsius of a difference.
The 550ti peaks at 90w of power consumption. The CPU peaks at maybe 60-80 watts.
A 850 watts power supply is ridiculously overkill for that system.
