Search In
  • More options...
Find results that contain...
Find results in...
Help to find a wall mount
I cannot find a wall mount for my monitor to mount on the wall.
Of course, I should mention that the monitor mounts on a VESA 100mm x 100mm. But I'm afraid of doing damage by buying some weird wall mount.
The monitor at the back has a recess. The VESA fits into that recess.
The stand that comes with the product shows small screws (attached to the stand that came with the product). I'm afraid that if I buy something from the internet I might find large screws and lose time.
The Monitor:
https://displaysolutions.samsung.com/monitor/detail/755/S29E790C
A standard VESA 100x100mm plate should fit in that recess, but if not, then placing some spacers between the plate and monitor then using longer mounting screws will take care of the problem.
