Search In
  • More options...
Find results that contain...
Find results in...
Problem slotting in an EVGA 3080 TI into mobo. Potential PC-O11 case design issue?
Need some help. I'm helping a friend with a build through the internet b/c they aren't very experienced. They are having issues slotting in their GPU into their mobo. It's a EVGA 3080 Ti FTW3, Lian Li PC-O11 Dynamic case (comes up later) and a ASrock x570 Velocita mobo.
The GPU plate flushes with the case, and the screw holes align. The issue is, the x16 connector is not slotting in. It ends up looking like this: Image 1
Due to that, if they let go of the card, it just falls down and out of the slot. So even thought the GPU plate if flushing against the case, the GPU is not slotting in.
I found some threads and videos that I might be related to the issue, where seemingly it seems to be a problem with the PC-O11 Case and its standoff screws. Thread 1, Thread 2, Video 1.
The thing is, there are multiple builds on the internet with PC-O11 Dynamic and EVGA 3080 FTW3, and the Ti version is the same size as the non-ti version. So I'm posting this here, seeking help. I already went through all basic troubleshooting, and this is definitely not a simple case of PCIe plastic cover, or latch issue. Not only that, but the I/O aligns perfectly with the case. Does anyone have personal knowledge of this case and this GPU, and ideally, of this MOBO all together?
they probably have the correct standoffs shipped in their boxes.
Pull the board out and check the standoff height and if it's wrong then order new ones and report back
Do you think that, since the I/O aligns perfectly with the current standoffs, it might be a problem replacing them with the taller ones?
i'd say you have a problem right now if they are too short so check what their height is and if its correct
if i ever have problem liek this i alwasy unscrew all the motherbaord screws a littl bit so it gives to gpu more "fickle room"
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
I'm afraid that did not do it, but it was worth a try
Any particular height I should compare it to? Or should I just also measure how much the connector is off the x16 PCIE slot and add that to the current standoff screws sizes?
yes pull them out and compare to standoffs from a machine that doesn't have the issue
