Vertically Mounted 3080 Ti in an NR200p w/ TG Panel - Temp concern
4 hours ago, FoodOcean said:If I'm going to use the vented side panel, I might as well side mount the rad lol. I guess another option would be to rock a airtower cpu cooler and mounted GPU horizontally...
If you're going to go with a tower cooler, you can watch machines & more on how to optimize airflow
And these are the cooler options for the nr200p.
I have a 5900x with the mugen 5 in the nr200p using the TG panel. My temps hit 90*C on the tdie and 91*C on the vrm with pbo and xmp when rendering. I have 5 arctic p12s mounted in the case. You'll definitely lose cooling performance going with a tower cooler unless its the noctua nhu-12a or c14s.
I'd go vented side panel and side mounted rad(fans as intake) with the gpu at the bottom in your situation.
