Ryzen 5700G Already Being Marked WAY UP.
Uttamattamakin
Summary
Before launch certain non US retailers such as PC Canada, PC Componentes (Spain), and PC21.FR (France) have it up for pre sales.
The following quote is based on older information.
Quotes
Quote
Thus far, the highest price that we've seen for the Ryzen 7 5700G is at $422 over in Canada, 18% higher than the MSRP. Surprisingly, pricing is better over at Europe where the markup is less than 10% before value-added tax (VAT). The Ryzen 5 5600G may cost up to 17% more expensive in Canada. On the contrary, the same chip could debut with a 10% higher price tag in Europe.
My thoughts
This makes no sense at all.  At over 400 USD it would be better to just buy a full pre built and swap the processors and then get a custom PC with the config and cooling etc so that the R7 5700G can really perform, and a secondary PC that can be used for other things.   Conversely, if one really does not care about graphics and will just muddle through with a GT 1030 or a second hand 10 series GPU get the Ryzen 5800X.  At 400USD this is not worth it unless one has a really specific need for AMD graphics but does not have either the slots or the budget for an AMD dGPU.
Since I built my custom computer on Mini ITX and I do have a need for AMD graphics this makes sense for me.  Ideally I would use it to host linux and guest Windows in a QEMU VM with a Nvidia dGPU.  So it might be worth lining up at a Microcenter or Best buy for it.
Sources
AMD's Ryzen 5000G Cezanne APUs Could Land With A Small Premium | Tom's Hardware (tomshardware.com)
I wonder how this compares to prices from 3000 series G processors from AMD. Their Ryzen APUs have always seemed to be in rather low supply and I imagine the global supply chain problems coupled with overall chip shortages and scalping haven't helped. I vaguely remember that the R5 3400G was also mostly in a similar situation for most of it's lifetime, especially in markets outside of the US (but maybe thats just me misremembering).
The free market will determine the pricing. It'll only stay at that price if people continue to buy up supply.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Fedora 38 x86_64
Secondary: AMD Ryzen 5 5600G, 16 GB 2667 MHz DDR4, Fedora 38 x86_64
Server: AMD Athlon PRO 3125GE, 32 GB 2667 MHz DDR4 ECC, TrueNAS Core 13.0-U5.1
Home Laptop: Intel Core i5-L16G7, 8 GB 4267 MHz LPDDR4x, Windows 11 Home 22H2 x86_64
Work Laptop: Intel Core i7-10510U, NVIDIA Quadro P520, 8 GB 2667 MHz DDR4, Windows 10 Pro 22H2 x86_64
5 hours ago, SlidewaysZ said:
That's the price of an entire steam deck and I bet the performance will be similar since it has rdna2 and ddr5.
If Steam Deck won't cost more than expected as well
The Ryzen 3200G and 3400G are hard to compare to the 5700G and 5600G for a lot of reasons.
The 3400G  has 4C 8T  and the  3200G has 4C 4T
The 5700G has 8C 16T and the 5600G 6C12 T
The 5700G (and 5800X really) are high-mid range parts  After them is the 5900 and 5900X baby Threadripper CPU's.
1 hour ago, Benji said:
What makes you think that the performance of a Vega 8 with DDR4 can compete with an 8-cluster RDNA2 chip coupled to LPDDR5 RAM? I'd think that the 5700G stands no real chance in the graphics department, but we'll see. The disadvantage in the Steam Deck is the fact that it only has a quad-core Zen 2 chip as opposed to the octa-core Zen 3 with a significantly higher power budget.
The 5700G stands no chance  against an APU with RDNA2 in terms of graphics.  However in the PC space it need to compete with that.  Basically it just has to be the ultimate expression of a socket AM4 APU.  The last of the dinosaurs before AM5 comes out. PLUS it can be paired with a dGPU and having two GPU's in a computer opens up possibilities and flexibilities.
You can literally get one for MSRP right now if your willing to pre order.
The main advantage the 5700G's graphics have is clockspeed and maturity of Vega 2.0 drivers.
Quote
This is why the real competitor to the Steam Deck's Van Gogh APU is 5700U or 5800U. In those cases the CPU is still stronger at the cost of presumably a much weaker GPU.
This trade off was unfortunately necessary because RDNA CUs take up about twice the space of Vega 1.0 and Vega 2.0 CUs.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
I should have said bare minimum. But yes the steam deck will have plenty of power.
I never understood why Ryzen APUs always seem so high priced, it's like they are more rare than normal Ryzens, even before the chip shortage.
At the time I got my 3400G for a pretty good deal (under $150). Since then I've never seen them at that price anymore and just go up, even $300 at some point. Same happened to the 3200G that was stable at $100 and since then always has been $120 or more until today.
The 2400G wasn't that popular, yet still marked up in price when new.
Now with the new Ryzen APUs, you would think the older APUs would drop in price, but they don't or just barely.
11 hours ago, Uttamattamakin said:
Summary
Quotes
My thoughts
Sources
Is this even news now?
I'd expect with time they'd really focus on much faster iGPU in the future, not in sense of just tech improvements but in general die wise size, like current consoles have as example.
| Ryzen 7 7800X3D | AM5 B650 Aorus Elite AX | G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | Sapphire PULSE Radeon RX 7900 XTX | Samsung 990 PRO 1TB with heatsink | Arctic Liquid Freezer II 360 | Seasonic Focus GX-850 | Lian Li Lanccool III | Mousepad: Skypad 3.0 XL / Zowie GTF-X | Mouse: Zowie S1-C | Keyboard: Ducky One 3 TKL (Cherry MX-Speed-Silver)Beyerdynamic MMX 300 (2nd Gen) | Acer XV272U | OS: Windows 11 |
i guess they could do like what intel done couples years ago on their " one of" intel nuc where they have i7 something-something and custom vega gpu in the same substrate, i think it was this vid
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
YES
If you are AMD a concern would be canibalizing low end GPU sales if the APU's are too good with graphics.  APU graphics will be worse than whatever the low end GPU is able to do.  However, given time that Low end GPU will still be so powerful that an APU will be enough for 75-95 percent of gamers.
Ah yes the Hades Canyon NUC.  That was an awesome product.  I'd love to see the abomination of an AMD CPU ... on the same package as ... NVIDIA graphics.  That will NEVER happen.  If it did it would kill Intel forever.
Well, what i had in mind is that, since the 5700g is single ccx (or from what I heard is) and so probably the next gen APU (hopefully), wouldn't it be nice if those "blank" space that "usually" get filled with other ccx is now filled with an rdna2 or whatever other gpu amd had in mind?
Yeah, I know it's sounds ridiculous and stupid
Tbh I don't see why people think that this is supposed to be something like a stand alone console or something. It's just an apu more targeted for people who don't need a dedicated gpu. If you are expecting dedicated gpu performance out of this I think you will be sorely disappointed.
You can only pre order, as you said. There is no guarantee preorders will be sent quickly, if at all. Some guys that preordered GPUs had to wait months only for the order to get cancelled.
6 hours ago, Uttamattamakin said:
YES
Game requirements, namely AAA titles, increase in complexity over time, and more recently, the trend seems to have accelerated with the introduction of ray tracing.
Additionally, we’ll hit the limits of silicon at some point. In lieu of a new technology, improvements will come from scaling up to match the ever-increasing demand of games.  Especially as 4K becomes the norm, and we start pushing for higher refresh rates, and even 8K in the years to come. The most cost effective means of scaling up is through the use of off-board coprocessors, namely dedicated GPUs. If anything, it’s in my opinion that there’s a greater chance of being forced to utilize multi-GPU setups to sustain further graphical improvements rather than settling on integrated solutions in perpetuity.
My eyes see the past…
My camera lens sees the present…
I'd been building HTPCs that run with the noctua NH-L12S. The 3400G was enough for mainstream titles like CSGO, DOTA, etc. The only issues come from games that need multithreading due to netcode complexity (fortnite, warframe, etc) or higher graphic thresholds. If you folk over in the west can't get your hands on GPUs at a reasonable price, then I don't think we'll be getting anything in this part of asia for at least ten years.
Graphics performance should be pretty close, the 5700G has a much higher power budget which is reflected in the difference in GPU clocks (1-1.6 vs 2ghz).
Sad but true.  GPU's are basically impossible to find unless one is willing to go for the VERY high end.  That said... the thought here in the west is that GPU production was being bought up by cryptominers in Asia right at the sources.  So who knows maybe if you have the funds you can grab some 30 series cards and sell em to us?
Think of the great number of people right now who are very happy to play DOTA Fornite and GTA V.  In five years todays AAA titles will be old hat and the APUs of that time will be RNDA 3.
1 hour ago, Uttamattamakin said:
-snip-the thought here in the west is that GPU production was being bought up by cryptominers in Asia right at the sources.  -snip-
AFAIK from speaking to OEMs and the manufacturer (AMD, NVIDIA), they've got restrictions on how GPUs can be sold:
1) Anything more than 2 per customer (per credit card used) has to go to a distributor or approved retail partner.
2) OEM allocations should maintain the same proportion allocation.
These are the two restrictions I can confirm exist, so my deduction is that miners have developed entire processes to get around the limits here. The usual retailers around southeast asia have put us all on a 3-month waiting list, and that's if they get stock too...
Yeah... I mean I wouldn't put it past the people running the factories to be in on this.  It's one thing for cards to be expenseive.  It is another when they basically don't exist for anyone anywhere.
Lets hope the APU's aren't the same story.
