Search In
  • More options...
Find results that contain...
Find results in...
what's the difference between 9 pin usb connector and the 20 pins?
Go to solution Solved by Skiiwee29,
9 pin is USB 2.0 and 20 pin is USB 3
PSU Tier List Thread
"White Ice"
Ryzen 9 5900x | Asus Crosshair VIII Hero (Wi-Fi) | EVGA RTX 2080ti | Ballistix 32gb 16-18-16-36 3600mhz | Custom Water Cooling Loop | 1tb Samsung 970 Evo
2tb Crucial MX500 SSD | 2x 3tb Seagate Drive | Fractal Design Meshify S2 |  EVGA G2 750w PSU | 3x Corsair LL140 | 3x Corsair LL120
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 32gb Gskill Flare X 3200mhz | Corsair RM550x | EVGA GTX 1060 3gb | 250gb 860 Evo m.2
Phanteks Enthoo Evolv |  Elgato HD60 Pro | Avermedia Live Gamer Duo | Avermedia 4k GC573 Capture Card
To expound - USB 3 is a superset of USB 2. It has the same wires as USB 2 plus some extras.
Regular USB has 4 wires, regular USB 3.0 has 4+5=9 wires.
The header connectors carry two USB hubs worth of data. I believe the extra pin/blank is there to help people figure out which way to plug in the connector.  USB 3.X staggers the pair of USB3 pins on the connectors (so not perfectly mirrored like USB2) presumably to reduce the effects of any electrical/RF interference. USB3 has tighter tolerances (they're moving 10x the data), so things like wire twisting pattern matter more.
R9 3900x | 64GB RAM | RTX 2080
1.5TB Optane P4800x | 2TB Micron 1100 SSD
HD800 | SR6011 + 4xB1 + PB12-nsb
QN90A | Topre Realforce Keyboard
