Search In
  • More options...
Find results that contain...
Find results in...
Can't seem to find PBO on B450 a-pro max
Go to solution Solved by rickeo,
As far as I can tell with some Googling, the 3200G doesn't support PBO anyway so I wouldn't worry about it.
I was looking for pbo and can't seem to find it
Cpu: 3200g
Mobo: b450 a-pro max
an iGPU gamer looking to upgrade
What's inside AMD Overclocking?
5800x/3090
just 3 settings for gfx stuff. like it literally says gfx on them
5800x/3090
