How big of a difference will be between 50~100$ MB and over 350$
Hey.
I am curious,
I am building a ~ sort of a budget pc for video editing.
Planing to use CPU from 10400 -> 10500 -> 10600k  will be decided latter.
This Pc will not be for gaming, maybe some SIMS 4 , not more than that.
So if I get a cheap MB, what I am expecting?
The cheapest MB is  Asus H510M-K LGA1200 Intel H51
So, how bad bottleneck we talk here?
If any at all?!
CPU - AMD 5800XMotherboard - ROG STRIX B550-E GAMING , Memory  - G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3600 ,
GPU - NVIDIA GeForce RTX 3080 Ti MSI SUPRIM X 12G,  Case - 4000D AIRFLOW Tempered Glass Mid - Tower ATX Case - Black ,
Storage - Samsung 970 EvoPlus 500GB - Samsung 870 EVO 1TB + 6TB HDD,
PSU - Corsair HX1000 , Display -  ASUS TUF Gaming VG27A 165HZ + Dell 24 UltraSharp Monitor , Cooling - Noctua NH-D15 Black ,
Keyboard - Razer Stalker , Mouse - Logitec G502 Wireless , Operating System - Win 10 Pro ,
Sound - Logitech Z906 5.1 THX Surround Sound Speaker System
A board can't be a "bottleneck". It doesn't work like that. As long as it has the features you need it's generally, fine. Though, there's some mobos that are just pure junk. Independent reviews will tell you that much, though.
What you pay more for is better chipsets, better power delivery, better quality, or when you start going really high, built in VRM water cooling and such.
For Intel, the main thing you need to pay attention to is the ability to overclock, particularly as it concerns XMP. Many chipset/CPU combos do not let you run XMP, which means you'll be stuck with something.like 2133MHz or 2666MHz RAM. RAM clockspeed tends to not matter as much with Intel, but you still want the ability to run XMP if you want. Because of this, there's certain pairings that don't make sense, as well. For example, there's absolutely no point to getting a K SKU CPU if you don't also get a Z mobo. The only point to the K SKU is overclocking, which you can only do on a Z chipset mobo.
You can generally, however, unlock power limits on any Intel CPU, in which case, you'd want to ensure you get a board with really good power delivery and VRMs (i.e. more premium and costly).
If you're just getting a bog standard Intel CPU, with no OC potential, you don't want to unlock power limits, and you don't care about XMP, then virtually any board will do, as long as it at least isn't just completely garbage in the first place.
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
Some cheap Intel boards fail to even deliver stock performance of some CPUs with higher TDP, so what you said isn't entirely accurate.
Don't get the cheapest...
There's is features benefit you will get from higher priced motherboard
Though there's certainly a point where "diminishing returns" kicks in and that's pretty much vary from person to person...
And that board has no heatsink on the vrm which is probably fine, but still no no in my book....
Just saying
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
What about when the board doesn't allow memory frequency over 2666 MT/s in this case. B560 at the very least will allow XMP and has no superimposed lock.
The problem with the cheap boards is power delivery. I got an iBuyPower with a i7 9700f and a gigabyte b365m ds3h wifi motherboard and had all kinds of issues with it.
Wouldn't let the thing boost the clock speed and would power throttle it to lower clock speeds. Had to install a program to manually change that stuff. The board is stripped down, only has 2 system fan headers and looks like shit.
I think the sweet spot for motherboards is $150-$200 depending on what you need. This is the cheapest board I've ever used and I'll never do it again
No cpu mobo or ram atm
2tb wd black gen 4 nvme
2tb seagate hdd
Corsair rm750x
Be quiet 500dx
Gigabyte m34wq 3440x1440
Xbox series x
I generally go with the $200 range and have been satisfied with em for the most part.
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
