Performance loss for running JEDEC ram?
32 minutes ago, Garak said:I've had issues with Corsair ram myself (a long time ago) so I'm actively avoiding them, and had a really bad RMA process about a year ago so all the more reason to. The Crucial ram I was looking at doesn't seem to be in the QVL list for whatever reason? Too risky to chance? It's quite cheap compared to everything else.
Don't suppose you could recommend a cooler for the 11400f while you're at it?
This RAM is cheaper and faster
I looked at the QVL and it seems to be very minimal but I wouldn't really worry, they list the much faster Crucial Elite 4000MT/s as compatible so this should work just fine as it's much easier to run. Crucial DRAM also tends to put less strain on IMC as it uses high secondary timings on their E-die.
Regarding cooling, I honestly have no idea what case you have and what price point you're looking at.
Despite the stupid name this is actually quite a good cooler for the price if you can fit it in your case.
