Search In
  • More options...
Find results that contain...
Find results in...
120mm fan choice for radiator help please.
I need 3 120mm fans that will be better then the stock 120mm ones on my kraken z73. they get so loud at anything over 60 percent on the fan curve. anyone got some suggestions on good fans that wont be like an airplane when at 16-1900rpm and are PWM... thanks prefer non rgb if possible.
Arctic P12s, Noctua NF-F12s Chromax would be my go-to for your needs.
PSU Tier List Thread
"White Ice"
Ryzen 9 5900x | Asus Crosshair VIII Hero (Wi-Fi) | EVGA RTX 2080ti | Ballistix 32gb 16-18-16-36 3600mhz | Custom Water Cooling Loop | 1tb Samsung 970 Evo
2tb Crucial MX500 SSD | 2x 3tb Seagate Drive | Fractal Design Meshify S2 |  EVGA G2 750w PSU | 3x Corsair LL140 | 3x Corsair LL120
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 32gb Gskill Flare X 3200mhz | Corsair RM550x | EVGA GTX 1060 3gb | 250gb 860 Evo m.2
Phanteks Enthoo Evolv |  Elgato HD60 Pro | Avermedia Live Gamer Duo | Avermedia 4k GC573 Capture Card
 NF-F12 iPPC for sure. I have the 3K and its really not bad for noise if you keep the revs low, like using the silent fan profile.. but that's no fun 🙂
AMD R9 5900X + Booost | Thermalright Frost Commander 140/2x iPPC 3K
Asus Strix B550-F | 4x8GB G.Skill Trident Z @ 1800 14-14-14-34 1T 1.425v
EVGA GTX 980 Classified @ 1500/1953 | WD SN750 500GB+1TB
Seasonic Prime GX-750 | Fractal Design Meshify C TG + Many CFM's
will the chromax be ok to install on a radiator considering they are "case" fans
Noctua NF-F12s are the best static pressure fans and the measuring stick for performance in fans. They absolutely will be the best fans to add to a radiator.
"White Ice"
The A12s actually outperform the F12s for radiator cooling.
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
