a motherboard should not store anything personal besides w10 code?
Solved by Helpful Tech Witch,
14 minutes ago, 12345678 said:not even sure if I ever enabled the tpm, I use to encrypt stuff with veracrypt..
anyway even if it was enable with just the key they shouldn't be able to do anything with it right?
Not really no.
like I said the settings for tpm have a clear option (or they should)
