Recommendations For Ultrawide Monitor Stand With Odd Desk Size
33 minutes ago, Tyvokka said:Would anyone have any recommendations for a monitor stand? My issue is that I'm struggling to find one that matches some very specific specifications, most notably the space/size available on the desk for a clamp.
My desk has a built in shelf that's resulting in most stands not being functional. I either need one that is small enough to fit into a space that's only 3.75in wide with room for me to be able to actually apply the clamp or it has to be big enough to span the entire gap and fit 5in in "desk thickness". The other specification for the arm is that it needs to hold 18.3lbs of weight for a single ultrawide monitor. Stands that just sit on the desk are also an issue, the shelf is only 7.75in deep, so most are either too big for the space or too small to reliably hold that large of a monitor.
Desk: https://www.amazon.com/gp/product/B07S11DQG6
Monitor: https://www.amazon.com/gp/product/B082XZKQN6
You can usually opt not to install the Monitor Riser shelf that comes with the desk for most desks that include it. That's what I'd do.
