PC wont work with XMP Profiles
so i will put a little backstory, i bought PC parts, they never arrived (except GPU) so in january i bought a a cheap interim PC until my parts actually arrived (intel i5 7600k, 16gb gskill trident ram, and i threw in my 2080 super) just yesterday my parts arrived, i put my PC together today i got it up and running however i ran into a few issues my drives wouldnt show up was the first issue, i fixed that by putting the sata cables into a different slot, load up the PC again, had a blue screen error (forgot what it said) i basically just put it into bios and left and it booted normally. now my PC is running the drives are showing but it randomly disconnects from the internet for half a second my discord would kick me in and out of call, any streams i had open would go to an error and i would have to keep refreshing. i turned off the computer and turned off xmp profiles worked like a charm, i just got done playing on it for 4 hours and didnt have an issue, however i would like my ram to run at advertised speed and im wondering if anybody has a fix, right now i havent had an issue with internet cutting out, but trying to load up battlefield 4 just keeps ending up in crashes there is no real "error message" other than the 1 blue screen i got..
my specs:
B450 Tomahawk Max
Ryzen 7 3700X
2080 Super
32GB Ram (16gb corsair vengeance 16gb GSkill) yes i get the issue still with each set of ram, i have tried
edit: i said i didnt have the disconnect issue but within 1 minute of posting this, i actually got it, added screenshot
List the full specs for each, or provide part numbers.
BabyBlu (Primary):
  • CPU: Intel Core i9 9900K @ up to 5.3GHz, 5.0GHz all-core, delidded
  • Motherboard: Asus Maximus XI Hero
  • RAM: G.Skill Trident Z RGB 4x8GB DDR4-3200 @ 4000MHz 16-18-18-34
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2070MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 10 Pro
Roxanne (Wife Build):
  • CPU: Intel Core i7 4790K @ up to 5.0GHz, 4.8Ghz all-core, relidded w/ LM
  • Motherboard: Asus Z97A
  • RAM: G.Skill Sniper 4x8GB DDR3-2400 @ 10-12-12-24
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Corsair Vengeance C70, w/ Custom Side-Panel Window
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair AX760
  • Display: Samsung C27JG56 27" 2560x1440 144Hz Freesync
  • Cooling: Corsair H115i RGB
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
both are 3000Mhz, i can straight up link the amazon for the corsair ram since i purchased it
https://www.amazon.com.au/Corsair-Vengeance-3000MHz-Desktop-Memory/dp/B0134EW7G8/ref=sr_1_1?dchild=1&keywords=corsair+3000mhz+ram&qid=1624543483&sr=8-1
the gskill is still 3000mhz but i dont know anything else about it, since it just came in the other system i purchased, there are no stickers on it
You can use software also to find out.
CPU-Z can check RAM so can Speccy.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
Okay. And you said you tried each kit alone, and the problem persisted. To be explicit: You tried running the XMP profile with only one or the other kit installed in the correct slots according to the motherboard manual(slots A2 and B2), and the problem persisted?
Another question:
Did you fresh install Windows with the new PC, or did you just move the drive and continue to use a Windows installation from the "interim PC".
BabyBlu (Primary):
BigBox (HTPC):
  • Display: None
NAS:
  • Synology DS216J
Another question:
correct, i tried each set separately and the problem persisted with both and i just transferred my drives over, an m.2 and ssd, i also added another ssd (i havent formatted that one yet)
I think I know what you mean, but I don't want to make assumptions. Can you say this again more clearly?
BabyBlu (Primary):
BigBox (HTPC):
  • Display: None
NAS:
  • Synology DS216J
i tried only the corsair ram, had the same problem, tried only the gskill ram, had the same problem
i just took the ram out of their corresponding slots so it would have been a1, b1 on the corsair a2, b2 gskill when i tested them.
This would never work. Try A2 B2.
BabyBlu (Primary):
BigBox (HTPC):
  • Display: None
NAS:
  • Synology DS216J
If you go over the motherboard manual carefully and have made sure you have done everything correctly and you still have issues return the board.
The last 2 computers I have built had motherboard issues so they were returned and the replacements have worked perfectly.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
so the problem with this is, i actually bought the board out of country, a friend bought sent it to me because early during covid literally nothing was available where i live in terms of PC parts, USPS just took a long ass time sending it to me. it was sitting in a warehouse for almost a year before being shipped.
i will try this, my friend told me it might be a voltages issue or something.
Before we can figure that out, we first have to be sure the RAM is installed correctly, and that each kit is independently tested.
BabyBlu (Primary):
BigBox (HTPC):
  • Display: None
NAS:
  • Synology DS216J
yeah so did u reset bios every time when swapping the ram? because  that may still have the wrong timings or something.
And what happens without XMP, any issues?
edit: ok and the Ram was probably in the wrong slots too… that would b an easy fix, for one kit.
Do you even need 2 kits? why?
generally faster Ram is preferred over more Ram, but maybe you *need* that much for something.
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
i definitely dont need more ram, its helpful when i do some editing but not needed, i just had it lying around and im more than happy to go without it, if it fixes everything. i will try everything when i get home a bit later
I'd strongly recommend reinstalling windows. You took an Intel install over to an amd system, funky thinks could be at play.
so an update, i did a clean reinstall of windows, and now both ram work separately, however they still dont work together cpu-z tells me the timings are slightly off, one is 17,17,35 the other is 16,16,35 both 1.35 volts.
is there a way to change tune the timings? i would really prefer to use both if possible
You could run both on 1,35V and 17,17,35 timings.
(Thus making the slightly faster one slow donw a bit to match the other set.)
But you would have to most likely do all this manually.
Maybe just using the 1 set on XMP will be way easier. You could sell the other and maybe get a 32GB set. (that will for sure work).
Great! That would have been my next recommendation after testing the kits independently.
This will likely work, but not guaranteed because there still may be problems with secondary or tertiary timing compatibility. The most likely configuration for this to work would be to set the timings and voltage as described above, but also configure the RAM as follows:
Instead of like this, where one kit is in A1/B1 and the other is in A2/B2:
II II
Configure it like this so that one kit is entirely in channel A (A1/A2) and the other is entirely in channel B (B1/B2):
II II
BabyBlu (Primary):
BigBox (HTPC):
  • Display: None
NAS:
  • Synology DS216J
II II
II II
thanks for the tip, will try to get all this done sometime next week, im waiting for some fans in the mail so i will probably do it then
