TVB problem with i7 10870H
1 hour ago, omidzare said:90+ on CPU
That is a normal operating temperature for a modern gaming laptop with an Intel mobile CPU. Most similar laptops run at these temperatures. Your computer has much better cooling than many I have seen.
Some 10th Gen mobile CPUs are only stable at an undervolt of -70 mV. Undervolting that is only available in the BIOS is a good idea to prevent any Plundervolt security issues. Not being able to adjust the size of the undervolt is a bad idea. If your CPU is not 100% stable at -80 mV then you cannot use this feature at all. MSI was smart. They include a hidden BIOS option so enthusiasts can unlock CPU voltage control and MSI owners can also disable TVB.
1 hour ago, omidzare said:the handicap of the CPU performance.
I see no evidence of the CPU being handicapped. Your 10870H is running at the correct speed when all 8 cores are active.
Not the slightest hint of any throttling other than the TVB throttling which is part of the Intel design.
Thermal Velocity Boost (TVB) throttling is a feature of these CPUs. When they exceed approximately 65°C or 70°C, TVB throttling kicks in and the CPU slows down 100 MHz. It is nice when laptop manufacturers allow you to disable this throttling feature in the BIOS but they are not required to do so. Your cooling is good so TVB throttling is really not that necessary.
1 hour ago, omidzare said:reinstalling the windows
Why? It is not Windows that has locked out TVB and CPU voltage control. It is the BIOS that is responsible for locking your CPU. Reinstalling Windows is not going to change the turbo ratio limits. These are built into the CPU.
Open the Task Manager, go to the Details tab and find out what is running on your computer. Get rid of any unnecessary background tasks if you want your CPU to run faster when lightly loaded.
