How fragile are psu ac power ports?
Solved by Guest,
2 minutes ago, Niklas1120 said:Oh. Ive just noticed the port itself wiggles a bit with the cable, but its veeeeery slight and my old psu does the same ting after 8 years of use. So the port is supposed to have some movement to it?
Yep. Every power supply I've ever owned has a very slight wiggle to the port. Not like it's cemented in place or anything, especially since it's made of plastic.
