GPU fan spinning but no display!
Solved by da na,
There's something wrong with that GPU. That's most likely a dead graphics card, sadly. Shutdown and fans ramping up is an issue usually caused by shutdown from overheating, and shutting off the PSU may have made it worse. Or, you just watched your GPU die. Unfortunately, there's nothing you can do. You could try putting it in the oven (no seriously, I'm not trolling, it's called a reflow and can help fix degraded solder joints. Just take as much plastic off the card as you can before you do.) but beyond that there's not much.
Edit: It's been a while since I've heard the name Inno3D... that was a bit nostalgic
