Which fan connector on my Asrock B450m Pro 4
Solved by Pigeon_Milk,
The fan on your cpu cooler should attach to 3. The three fans can attach to either 16, 17 or 26 is doesn't matter, the CHA_FAN 1/2/3 is just how it is labeled in the bios so you can control the speed it doesn't really mean anything. Hope this helps
minato ·
Posted in New Builds and Planning1 -
4
ShadowChaser ·
Nicolas Bossus ·
Lota_9 ·
Posted in Storage Devices2 -
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
