how much power suppy i need aor psu suggest me
Solved by Omar.B,
1 hour ago, krypton0411 said:i am new i dont know anything
Welcome to the Forum!
Its ok , a ryzen 3600 doesn't take much power even pairing it with 1650 450w should be enough if you are looking for a budget psu if you got some money and planning to upgrade in the future a 650-750w gold (efficiency) should be enough for everything
kacper6768 ·
Posted in Displays1 -
Minuto ·
Posted in Troubleshooting0 -
Williamgame08 ·
Posted in Power Supplies1 -
2
RagePoweredGamer ·
Posted in Troubleshooting16 -
14
Cookiey ·
brau508 ·
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
