First build (yet to order parts). Any tips in advance?
Solved by dizmo,
16 hours ago, Somerandomtechyboi said:Just swap the case out for better airflow cause some of these prebuilts have some god awful airflow to the point that everything inside the case overheats xD
Those ones often don't use standard motherboard sizing so you can't swap them out.
Onions ·
Posted in Linux, macOS and Everything Not-Windows0 -
1
SyndiShanX ·
Posted in Audio6 -
Nexxus ·
Posted in Programs, Apps and Websites3 -
ds5018 ·
Posted in Troubleshooting5 -
5
Muzzy2002 ·
Posted in New Builds and Planning4 -
modern_officer ·
Posted in Laptops and Pre-Built Systems5 -
5
Coding2bLazy ·
Posted in Troubleshooting9
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
