My pc won’t boot up after changing the boot up drive :/
Solved by NinJake,
Yes once you download the media creation tool onto your computer, you run the executable and at some point you'll have the option to "upgrade this pc" or "create installation media for another pc" or something along those lines. You want the 2nd option for another pc, it'll ask you to plug in a usb drive and then you install it to the drive. after that's complete you plug it in your problem pc and boot from it to start a fresh installation.
If that's not clear, there should be instructions on that page I linked from microsoft, but the main thing you DONT want to do is "download the tool" and drag it onto the usb drive, you need to install it to the drive. @Shookyoo
