Microlab TMN1 4:1 FR port problem
It could probably be fixed.
Could be something as simple as replacing a capacitor (half a dollar) , or it could be more complex like replacing an opamp (1-2$), some voltage regulator, some transistor, maybe the audio IC (a few dollars)
Could also be something basic like the wire going to the connector being broken / loose / not making good contact inside.
Someone has to open it up, inspect the circuit board, if the flaw isn't visible directly with eyes maybe make some measurements, check various components ... that means it would cost maybe 30 minutes - 1h of work time...
if you're not afraid, maybe open it up and take some pictures of the electronics inside just in case it's something obvious you could fix by yourself. Make sure you unplug it first.
// i see you posted this on tom's hardware as well ... doubt they can be more helpful..
