Help regarding RGB software support for MSI B550-A PRO
1 hour ago, Zeredos said:Very sorry for the late reply i've just been really busy, i shouldn't of necessarily said obviously, but my whole stigma with Mystic Light is not with it itself but rather as you said the fact they have integrated it into their Dragon Center. Which i've seen a surprising amount of complaints about from people for various things, from it running horribly to messing with people's WIFI etc. That with the fact it doesn't have my board listed as supported as well as me just wanting to avoid Dragon Center all together is why i've ended up looking/asking different alternatives.
But to re-iterate, what alternatives i have looked at either require Mystic Light and by extension Dragon Center now i guess, or just don't list my board/B550 boards at all on their support lists. Seeing how as this is my first PC, i'd rather not take chances i don't need too to "test the water" so to speak, when i can just refer to a more experienced source of information for help. But you've said it right brotha, finicky is definitely a word to describe this pickle and i'm honestly after a month and a half of rainbow vomit just getting tired of it heh.
if you want to use the mb rgb/argb headers you need the msi rgb software... jacknet and open rgb i think need that installed to beable to control the headers.
all rgb software is bloatware and if you dont want to risk it them maybe an manual remote controller or controller with buttons is the best option.
Gelid Solutions AMBER5 is what i recommend has like 366 presets...
