Water Cooling a Zotac 1070 Mini
Accessless
As buying a new graphics card at the moment impossible I thought that I would try my hand at water cooling my system. However sensibly at the moment companies are only producing water blocks for 20-series cards and up. I have found this block: https://www.watercoolinguk.co.uk/p/EK-Water-Blocks-EK-Thermosphere-Nickel_69762.html (assuming that I can get the correct mounting).
Does anyone have any recommendations about VRM and VRAM heatsinks as this block only covers the die itself. Will passive cooling do?
I would not recommend passive cooling at all. They do make little copper heatsinks you could thermal epoxy down, but that’s a semi permanent solution….. which you may not want.
I wouldn’t watercool unless you can find a full cover block.
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
