Search In
  • More options...
Find results that contain...
Find results in...
I spilled water on my blue snowball ice what do i do?
I spilled Water on my blue snowball ice and i don't know what to do can you help me???
Let it dry out and then see if it works?
Emma : i9 9900K 5.1Ghz All-Core - Gigabyte AORUS Z370 Gaming 5 - Tt Water 3.0 Ultimate 360mm AIO - G. Skill Ripjaws V 32GB 3200Mhz - Gigabyte AORUS 1080Ti - 750 EVO 512GB + 2x 860 EVO 1TB M.2 (RAID 0) - EVGA Supernova 650 P2 - Fractal Design Define R6 - AOC AGON 35" 3440x1440 100Hz - Mackie CR5BT - Logitech G910, G502, G933 - Cooler Master Universal Graphics Card Holder
Plex : Ryzen 5 1600 (stock) - Gigabyte B450M-DS3H - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - 840 EVO 256GB + Toshiba P300 3TB - TP-Link AC1900 PCIe Wifi - Cooler Master MasterWatt Lite 500 - Antec Nine Hundred - Dell 24"
Lenovo 720S Touch 15.6" - i7 7700HQ, 16GB RAM, 512GB NVMe SSD, 1050Ti, 4K touchscreen
MSI GF62 - i7 7700HQ, 16GB 2400 MHz RAM, 256GB NVMe SSD + 1TB 7200rpm HDD, 1050Ti
Other Tech - 2021 Volvo S60 Recharge T8 Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Thank you but how long????
electronics actually don't hate water.
Electricity hates water.
If you let it FULLY DRY OUT.  You've got a very solid chance it'll survive.
(If it was powered when you spilled?  Well, that's just making it a roll of the dice.)
Stick it in front of a fan and let the air dry it out.
How long?  At least 36-48 hours.  If there are any panels you can open up?  That'll help.
about a day maybe two.
I am not responsible for any damages or problems to your device or object.
Main Z490 RIG:
Intel Core i9 10850K w/ Noctua chromax.black NH-D15
Corsair Vengeance 2x8GB 2633MHz
ASUS STRIX ROG Z490-E
EVGA GeForce RTX 3060 Ti FTW3
WD BLACK 500GB NVMe, 1 TB WD Black Hard Drive, 3 x Seagate Barracuda (Raid 0), 2TB Seagate FireCuda NVMe
Corsair CX650F White RGB
Lian Li O11D-W XL
PewDiePie Limited Edition Ghost M1 Mouse
PewDiePie Limited Edition Ghost A1 Keyboard
Windows 11 Pro for Workstations Dev
HP Z600 (NAS):
2x Intel Xeon X5670 @ 2.93 GHz
2x 2TB WD RED in Raid 0
48 GB of DDR3 ECC Memory
500GB Seagate Barracuda SSD
Uses: Plex Media Server, Minor Storage
Windows Server 2019 Standard
Certificates:
A+ Entry-Level Computer Certification
Certified De-icing Technician
ok
Would it be safe to test the mic if not please tell me
Wait around a day then test it out, worst that could happen is that it stops working
geometry is hard
b550 > x570
not until you've given it time to dry out.  You can't have electricity and water in the same place.  That lets out the magic blue smoke.
Also:  don't make more junk threads less than 20 minutes apart, this is still part of the old thread.
Put it in rice.
GAMING RIG:
CPU: Ryzen 5 5600x (Lazy OC - Not fine tuned. PBO Tuning)
MOBO: ASUS TUF Gaming X570 PLUS (Wi-Fi)
RAM: 32GB G.Skill Ripjaws @ 3600MHz
GPU: Zotac RTX 2080 Super (Mild OC - Still Testing)
STORAGE: 500GB Crucial MX500 M.2 (Boot Drive) / 500GB Crucial SATA / 1 HDD
CASE: Dimas Tech EasyBench V3.0
Threads merged. Please continue discussions in the existing threads rather than making a new post. If you make a new post the people reading it won't be able to see the previous discussion and what has already been suggested to help.
So i think it only spilled on the back of the snowball
13 minutes ago, SirWendall said:
Put it in rice.
Don't put it in rice.  There is rice dust that can get into the component.
Rice absorbs water, yes.  Air drying does the same thing.
Leave it alone for a couple days, or put it in the path of moving air to help it.
