Search In
  • More options...
Find results that contain...
Find results in...
How is my build???
Go to solution Solved by jaslion,
https://pcpartpicker.com/list/XsNxBc
Cheaper overall, no performance loss and allows you a bigger budget for the gpu.
Case has good airflow instead of the bad h510 too.
1 minute ago, Ziadahmed2412008 said:
https://pcpartpicker.com/list/nDddht
I have a budget of 1500usd any comments should i edited anything in this build
This list needs alot of change, but we need to know -
-When you plan to buy
-Your country
-What you are using the PC for.
geometry is hard
b550 > x570
looks pretty solid, youre probably not going to get that card for 500$ up
id disagree.
geometry is hard
b550 > x570
-Your country
I want to buy it like in the next month
My country egypt
Gaming and maybe streaming
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($299.00 @ B&H)
Motherboard: MSI MPG B550 GAMING EDGE WIFI ATX AM4 Motherboard  ($172.00 @ Walmart)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($74.99 @ Newegg)
Storage: Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive  ($119.99 @ Amazon)
Video Card: NVIDIA GeForce RTX 3080 10 GB Founders Edition Video Card  ($700.00)
Case: Phanteks Eclipse P360A ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: MSI MPG A-GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($94.97 @ Amazon)
Total: $1530.94
Generated by PCPartPicker 2021-06-14 08:34 EDT-0400
geometry is hard
b550 > x570
Total: $1530.94
I think it wont be possible to get the 3080 at that price this year
