CPU w/ x62 Kraken and AIO GPU (EVGA 3080Ti Hybrid)?
Andreas Lilja
Can a Phanteks Primo accommodate both or even any case period?
Desktop: 7800x3d @ stock, 64gb ddr4 @ 6000, 3080Ti, x670 Asus Strix
Laptop: Dell G3 15 - i7-8750h @ stock, 16gb ddr4 @ 2666, 1050Ti
Seems like it’s more “can the required radiators be mounted?”  1x 420mm and 1 480mm or something?
The Phanteks Primo was one of the best for its time but not a good fit for what we know now about AIO placement.
I bought a Corsair 5000D. It has enough room to do a push-pull 360mm AIO on top and a hybrid AIO radiator on the side. Even the 3 fan Kingpin would fit.
I bought it since I did an auto notify on all the EVGA hybrids and none of my existing cases could fit the 240mm and 360mm EVGA uses without restricting air flow.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
If I buy the Corsair it will fit?
Right now I have my old i7 8086k setup in it for testing.
I have the 360mm fans on top and there is room for a second set below. The white panel right of the motherboard is removable and the hybrid AIO would fit there.
The other side of the case.
When I get a hybrid I will be testing to see if it is better mounter on the front or on the side.
