will this work for a capture card
shreklover09
i want to make a ds lite capture card i will get one of these thumbnail - 0 usb 5p or miny b to usb c then i will get one of these Twitch Micro USB Magnetic Adapter For iPhone Xiaomi Huawei Samsung Micro USB Female To Type C iOS Male Magnetic Adapter Charging usb c to hdmi will that work
my friend said it will not work but i know it will work
Can you link to the two items that you're showing? The images you linked are super tiny and I can't tell what they are.
elephants
https://www.wish.com/product/5d7c3b70bf0a850954b89ac6?share=web the usb miny b to type c
type c to hdmi https://www.aliexpress.com/item/4001196236107.html?spm=a2g0s.9042311.0.0.7e814c4dX72uWM
Nope, will not work. The DS Lite does NOT have a Mini-USB port on it - it's got a special Nintendo proprietary port that has 2 connections - power and ground. No data involved.
elephants
i kind of bought it............. yeah idk i am still going to try it yeah....
1 minute ago, shreklover09 said:
Yeah for charging. That port is ONLY POWER it is NOT DATA. There is NO DATA that goes through it so it will NOT work.
i saw a video like this
That does nothing for you, because as we explained there is NO DATA going through that port. It has 2 conductors - power and ground. NO DATA at all goes through that port.
Your idea will not work and buying those things will be a waste of money for a DS Lite.
elephants
How do you plan to add data or video ports?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
That is a android tablet WITH DATA OUT.
The ds lite literally ONLY HAS POWER FROM THAT PORT. There is NO DATA WHAT SO EVER.
i know it probily not going to work its worth a try right '
There is a 0% chance it will work. No chance at all. Do NOT waste your money.
Why? As we explained, the DS Lite's charging port carries NO DATA. AT ALL.
Just power, to charge the battery. Without data, there's no video data to record, meaning your idea will not work.
Do not waste your money.
elephants
I kind of already did it yeah
how about a aux cord idk
Nope. Aux cord only does sound and sound does not carry video data.
I guarantee you can cancel your order.
elephants
Nintendo DS Lite Charger Cable allows recharging your NDSL through USB port of PC. You can use it as Data Transfer cable or USB Charging Cable
It's lying. The DS Lite's charging port has NO DATA LINES.
There absolutely no way possible to transfer data over that port. Zero. Nada. Zilch.
elephants
idkk
i kind of bought it 99% will not work 1% willl work
Wrong. 10000000% chance it will not work 0% chance it will work.
There is no way for it to work, as we've explained numerous times.
Please. Cancel your order. It's a waste of money.
elephants
It will not work 100%. It cannot work it is literally impossible.
Why can't you just return it or cancel it?
Also, "1% will work" is wrong. its literally impossible as @jaslionand @FakeKGB have said multiple times.
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
how about the 2ds
