Search In
  • More options...
Find results that contain...
Find results in...
(HELP) MSI MPG B550 GAMING EDGE WIFI BIOS FLASH
Hi, i've got the mpg b550 gaming edge wifi, when i tried to flash the bios (cause i have the 5600x), only the LED at the flash bios button light up. unlike the one that i see on youtube same model of MB as me, they have all their MB Led light up. anyone know what happen?
Did you make sure to flash the correct BIOS to the mobo?
GAMING RIG:
CPU: Ryzen 5 5600x (Lazy OC - Not fine tuned. PBO Tuning)
MOBO: ASUS TUF Gaming X570 PLUS (Wi-Fi)
RAM: 32GB G.Skill Ripjaws @ 3600MHz
GPU: Zotac RTX 2080 Super (Mild OC - Still Testing)
STORAGE: 500GB Crucial MX500 M.2 (Boot Drive) / 500GB Crucial SATA / 1 HDD
CASE: Dimas Tech EasyBench V3.0
The 5600x would have been supported out of the box.
Were you having POST problems and decided to update for that?
PSU Tier List      AMD Motherboard Tier List      SSD Tier List
If I helped you out, please leave a thumbs up. It's appreciated.
If your issue is resolved, please share the fix with the community.
-> Moved to Troubleshooting
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
