Another lian li build.
Volanaro
hey guys so, here is my lian li build so far, work in progress, i just installed the distro plate, looks loads better, but what a pain to bleed lol, anyway, im thinking cooler master Master fans in white for the next upgrade, what could i do better? im wanting to stick to soft tube,
plan is
new fans
Rgb hub 3/4 pin compatible so i can use both leds on my ek blocks as they are different.. any ideas here?
before and after pics,
im running a 6700k, 1080ti, 16gb ram
asus z270 tuf
the rgb spectrum was only for my 18 month old haha i tend to  run blue. or purple 😛
Nice pc!! I'm thinking about buying this case paired with a ASUS Rtx 3090, Ryzen 9 5950x and 128gb of ram, and a x570 motherboard
