I5 7400 CPU only uses 21-23 watts max
Solved by JoostinOnline,
14 minutes ago, Mosh_E said:
A software estimate is not going to be accurate. Plus, TDP is not really how much power your CPU will use. It's just a general classification of how much heat it can output. On top of that, your testing methodology is very flawed. Maxing out the graphics settings will reduce the impact on the CPU, or do nothing. All you're doing is putting more load on the GPU.
