Help with How to set maximum memory trough CMD.
Solved by Kilrah,
Like for the numproc as explained above you can delete the max memory value you've set with bcdedit, the value being truncatememory.
And don't mess with this, almost every time someone sets a number of CPUs or max memory there it's not actually a valid solution for the issue they're trying to fix.
