Search In
  • More options...
Find results that contain...
Find results in...
Best way to run SAS HDDs at home
Where I work they're going to throw quite some 2TB SAS hard drives (they're upgrading storage capacity, but the drives are ok) and I thought I could use them to backup images (In addition to a cloud backup that I'm using)
What is the best (Not too expensive) way to run these SAS drives at home (and connect them to my PC)
Thanks
Thanks
Walmart sells a SAS to Sata conversion adaptor for a bit under $8. I can’t speak to how well they do it though.
While sas controller can work in sata drive, sas drive cannot work with sata controller
Quote
The use of SATA hard drives on SAS controllers is made possible by the fact that both share the same infrastructure and have similar features. SATA drives may be plugged into SAS controllers. SAS drives cannot be plugged into SATA controllers.
so unless your motherboard support sas option in the bios you have to buy HBA card like this one
https://www.amazon.com/SAS9211-8I-8PORT-Int-Sata-Pcie/dp/B002RL8I7M
Thanks
Need a HBA as @Liam danu said, but they don't need to be that expensive. I  think I got mine for like 40-50 bucks?
Rig: i7 10700k @ 5.1Ghz, 4.8 Ring - - Z490 Vision G - - EVGA RTX 2080 XC Ultra @ 2025Mhz - - 4x8GB Vengeance Pro 3000Mhz 15-17-17-34 @ 3500MHz 16-19-19-38 - - Samsung 950 Pro 512 NVMe Boot + Main Programs - - Samsung 830 Pro 256 RAID 0 Lightroom + Photo work - - WD Blue 1 TB SSD for Games - - Corsair RM850x - - Sound BlasterX EA-5 - - EK Supremacy Evo - - XT45 X-Flow 420 + UT60 280 rads - - EK Full Cover GPU Block - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - Steel Series QcK XXL
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: ESXi 6.5 - - 250 GB SSD for VM's/ESXi boot - - FreeNAS - - HPE Proliant ML10 Gen 9 backbone - - i3 6100 - - 28 GB ECC - - 10x4 TB WD Red RAID Z2 - - 10TB WD Red for expendable data - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander
White Lightning (original full watercooled build) - Homelab / Media Server - The Blue Beast (my car and other expensive hobby...) - iPhone Xs - 2018 MacBook Air
