Search In
  • More options...
Find results that contain...
Find results in...
980 G1 4gb power consumption
I recently ordered a gigabyte 980 g1 4gb for my first pc (I’m really just aiming for 1080p gaming). I wanna know if my current psu can handle the gpu wattage wise.
In my last post I was planning on getting an rx570 but I struck a deal with this card. I know my current psu has a worse design and I’ll prob upgrade to a cx-550 soon
my specs:
i5-10400
Gigabyte Aorus b460m pro
HyperX 2x8gb 2666mhz
Gigabyte p450b psu
Main: AMD Ryzen 7 2700X, Nvidia RTX 2060, 16 GB 2400 MT/s DDR4 Fedora 34 x86_64
Secondary: Intel Xeon W3680, AMD Radeon HD 6950, 24 GB 1333 MT/s DDR3 Windows 10 Home x86_64
Server: 2x Intel Xeon X5670, 72 GB 1333 MT/s DDR3-R Ubuntu Server 20.04.1 LTS x86_64
Laptop: Intel Core i5-3320M, 16 GB 1600 MT/s DDR3 Fedora 34 x86_64
my specs:
i5-10400
Gigabyte p450b psu
The 980 has a very high TDP, so you will probably need a 600W at the least
Another day another PC part picker list bullied.
Probably the best and most in depth PC build guide, great for beginners https://www.youtube.com/watch?v=dQw4w9WgXcQ
⬇️ Specs Below⬇️
CPU: Ryzen 3 2200G@3.5GHz
COOLER: AMD Wraith Stealth Cooler
GPU: Uh.. imagine having one of those, cringe
MOBO: Gigabyte A320M-S2H
MEMORY: 16 GB OLOy DDR4@3200 (2x8GB)
STORAGE: Kingston A400, 240 GB
PSU: ARESGAME AGV500 (500 WATT)
CASE: MONTECH Flyer, Black
Ok thanks, ima upgrade sooner ig lol
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
it will run, but don't try to max it out with furmark+prime95 or smth. you can try to undervolt
22 minutes ago, 1saacF said:
It'll be safer to upgrade but it would run on my current system?
Yes, but this model is bad enough to be worth replacing.
Desktop benching:
If it helps I have a 980 Classified. If I bench my card at 1500/2000 with my CPU @ 4850 AC. I see close to 350w, but I really have to lean on the whole system to do it. If I just run @ 1417/1753 I rarely see 300w. Similar to my 3770K system.
Now I did run Furmark once with a good OC on the GPU, and my 3770K running Linpack Xtreme. Linpack and my CPU were chewing about 220-260w on its own (cant remember lol..) until I hit go on Furmark. Usage went to 750w and I let it run for a bit.. it was just straight up abusive. I wont run Furmark again. Its not that I cant, it just kicks the shit out of everything for no good reason.
AMD R9 5900X + Booost | Thermalright Frost Commander 140/2x iPPC 3000
Asus Strix B550-F | 16GB G.Skill Trident Z @ 1900MHz 15-15-15-36 2T 1.45v
EVGA GTX 980 Classified @ 1500/1953 | WD SN750 500GB+1TB, 2TB Spinners
Seasonic Prime GX-750 | Fractal Design Meshify C TG | 4x 120x38 Panaflo
Oh dang that crazy. But yeah I don’t plan on overclocking, I don’t even think my mobo supports that. I’m prob just gonna use it for 1080p gaming
