Difference Between 3600mhz CL18 vs 3600mhz CL16 for Gaming on Ryzen
How much performance am I really losing out on for gaming if I'm using 3600 CL18 vs 3600 CL16 with a Ryzen system? Is it worth paying the 10-30 dollars more for the CL16?
I have heard that lower聽cas-latency will make it feel more "snappy" (Like when you click something it will open faster.)
馃槼
Not that active so I may not respond.
From my understanding of CL (and I could be completely wrong here, in which case feel free to educate me), you are loosing around 12% "Reaction time".聽
If the ram task is a race, the CL 16 the "car" react and starts聽racing 2 cycle faster. So on smaller task, it's聽add up but it's not as remarkable as going up in Mhz.
CPU Ryzen 5900X - Motherboard Asus ROG STRIX X570-E - RAM 16GB of G.SKILL NEON 3600 -
GPU EVGA RTX 3080 XC3聽-聽Case Mastercase H500p mesh - PSU Seasonic Focus Gx-850 -
Corsair MP600 NVME 1 Tb,聽Samsung 960 PRO 500 Gb & 2 Seagate Baracuda 7200 RPM 2TB in stripe -
Display two VG27AQ 2K monitor - Cooling Corsair H150 Pro -聽
Keyboard G-910 W/ Romer G tactile - Mouse G 502 Hero (wired) -
Sound Logitech X-530 and Razer Tiamat headphones
Operating System Windows 10
Lower latency on ryzen often reuslts in better 1% and .1% lows, but it improves general performance too, so you would also see an increase to average frame rate and overall "smoothness" in a lot of ways.
CL18 3600 has the same latency as CL16 3200, and people often conclude that performance is just fine on 3200 CL16, even if lower latency is slightly better.
If the price difference is small, and the peace of mind from better performance (even if it's slight) is worth it, then go for it. But there generally isn't much of a drawback from opting for the CL18 kit.
Side note: if you get the ram and your system won't run at 3600MHz (for any number of reasons) you might end up manually tuning it and get the best of both worlds. My girlfriend's 2200G can't run the advertised 3600 speed of her memory, but I manually tuned it to 3466 and dropped the CL by a ton, so she has high bandwidth and low latency which delivers quite good performance.
Primary PC:
i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black聽(with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux聽- Black and green theme, Razer brainwashed me.
Trash beauty:
Xeon X5560 -聽RX 570 4GB (defective) -Fattydove Racing 240GB聽- WD Blue 320GB -聽HP Z400聽- 6x2GB DDR3 1066聽- EVGA 450W3
How many watts do I need?聽ATX 3.0 & PCIe 5.0 spec, PSU misconceptions, protections explained,聽group reg is bad
