mechanical keyboards Mechanical Keyboard building/buying help
2 hours ago, Doctor Clams said:
Hi I was looking into building my first mechanical keyboard and i need help with some parts
I would like a TKL board and hot swappable pcb. if possible a purple case would be idealHere's what i already have
Switches: NovelKeys Cream
Keycaps: GPBT Keycaps
Lube: Krytox 205G0
I have no PCBs ,Plate, or stabilizers currently
Thank you for any help in advance!
Currently the Radiance TKL GB is live and looks like it's the perfect match for you. Although you will have to buy the hot-swap PCB seperately.
Here's the link for the GB in the NA region https://keyspresso.ca/collections/group-buys-current/products/group-buy-radiance-tkl
and here's the link for the hot-swap PCB: https://keyspresso.ca/collections/group-buys-current/products/group-buy-radiance-tkl-add-ons-1
For the stabilizer, I recommend a set of Durock V2 stabilizer, link to it from the same vendor as the board: https://keyspresso.ca/collections/stabilizers/products/durock-stabilizers-v2
i also recommend wire balacing each stab and also Holee mod the stabs, guides on how to said mods are followed:
