Gigabyte H510M S2H review and guide
1 hour ago, Munhim said:Thanks for reply!! can you suggest a cheap board but not a trash one gen 4 doesn't matter.m.2 slot is a plus i have a optane so it be good if I can throw it in with my hdd.
Pcie gen 4.0 boards are expensive the best I can do is a 120$ b460 asrock steel legend board that is cheap. I do hope you have a normal ssd too as optane is NOT a replacement for a normal ssd it is merely a cache and it will NOT make a big difference at all if the hdd is your main drive.
Pcie is also forwards and backwards compatible so do not worry too much about it nothing is maxing out pcie 3.0 anyways. The only time it happens is if you do BIG BIG BIG data crunches (complex simulation rendering, extremely complex math, hard caching data,...) which normally nobody does except people that work in those lines of work and that is on work systems then.
