Need help on replacing a fan for my GPU
Hey, so one of my first posts so hope you bear with me.
I'm running a "Gigabyte GeForce GTX 980 4GB G1 GAMING" and one of its fans has decided to grant me its siren song. It's not hitting against anything but i hear a constant grinding kind of sound when it runs, it also can't spin up to max speed so is very slow. I've not seen that great of an impact on my temperatures, even did a thermal paste replacement since that had turned solid. nevertheless its a pain to listen to the fan, so i wanted to replace it.
I'm struggling to find any place i can buy a replacement fan however, and i was wondering if some people here, more tech-shop fantastic than me could help point me in the right direction.
I'd greatly appreciate it.
Not sure which size the fans are but maybe some of these can be used: (1) Gigabyte Graphics Card Fan Replacements – Tagged "triple"– GPU Fan Replacement
PC Setup:
HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel
Intel Core i7-10700K + Corsair Hydro Series H100x
G.SKILL TridentZ RGB 32GB (F4-3600C16Q-32GTZR)
ASUS ROG STRIX RTX 3080Ti OC LC
ASUS ROG STRIX Z490-G GAMING (Wi-Fi)
Samsung EVO Plus 1TB
Crucial MX500 2TB
Crucial MX300 1.TB
Corsair HX1200i
Peripherals:
Samsung Odyssey Neo G9 G95NC 57"
Samsung Odyssey Neo G7 32"
ASUS ROG Harpe Ace Aim Lab Edition Wireless
ASUS ROG Claymore II Wireless
ASUS ROG Sheath BLK LTD'
Corsair SP2500
Beyerdynamic TYGR 300R + FiiO K7 DAC/AMP
RØDE VideoMic II + Elgato WAVE Mic Arm
Racing SIM Setup:
Sim-Lab GT1 EVO Sim Racing Cockpit + Sim-Lab GT1 EVO Single Screen holder
Svive Racing D1 Seat
Samsung Odyssey G9 49"
Simagic Alpha Mini
Simagic GT4 (Dual Clutch)
CSL Elite Pedals V2
Logitech K400 Plus
i didn't even know that website existed, i took a look and this one seemed correct; https://www.gpufanreplacement.com/products/78-mm-gigabyte-gtx1050-1060-1070-1080-g1-n960-n970-4pin-gpu-fan-replacement?variant=1635841835026
description claims its compatible with my gpu so i've placed an order there. Thank you so much
Essentially the same fans without a gigabyte sticker.
  • 2 weeks later...
You live and you learn i guess.
So i got the fan but I originally forgot to check what connector the fan pin head was. Well its male and the connector on the gpu is as well, seems like its not a problem when you buy the full set of 3 fans since you get a cable but in my case where only one of my fans was broken, No deal.
