Search In
  • More options...
Find results that contain...
Find results in...
OBS Streams Perfect but Recording skips a frame every 5-10 minutes
Not sure if this the right place or not, but yea...
So I stream on twitch using a PC + Capture Card. I also use OBS to record to a local storage, for obvious reasons.
PC SPECS:
-Ryzen 5 3600
-Gigabyte Aorus X570 Elite w/ Wifi [I am hardwired, WIFI is just for when I need to fix the Hardwire/router]
-GTX 1660 Super
-MSI Mag CoreLiquid 240R
My issue is when I'm streaming, everything is perfectly fine with the stream, no dropped frames, nothing. but when I watch the gameplay recording for my video edits, everything is smooth as silk, then 1 frame skips, runs smooth again for 5-10 minutes, then another frame skipped.
Most the YT videos, and other sources I've checked to solve this issue all say lower my game settings, but I play on console, so those tips don't help.
Thanks in advanced!
Welcome to the forums!
If it's skipping a single frame every 5-10 minutes, is it really a big deal? If it's skipping like 10-20 frames, that's concerning. There may be an issue with the encoder
As Someone with the username “</TheCoder2019_”, my coding skills are atrocious.
As Someone at the age of 2.338 alien years (whatever that is), built a not terrible but a “gameable” system for $500 USD
As Someone with atrocious coding skills, knows more Unix/Bash more than CMD
Here are my specs:
MSI PRO-VLH H310M
Intel Celeron G4960 (2 whopping cores!)
GTX 1050 Ti 4GB
16GB (2x8) Cosair Vengeance LPX CL16 - 2400MHz
A Rosewill case I found on eBay (SRM-01B Black)
An old friend of mine - Intel stock cooler (temps through the roof like 90 C under load)
Linux Apps you NEED!
tmux
dhcpd
git
Hi! I love RGB! Who doesn't? Karens that don't have colorful lights on their Facebook page
well i guess it skips a few frames.. not just one.. sorry .. i just meant it would skip for a moment
