Search In
  • More options...
Find results that contain...
Find results in...
Is my power cable okay like this?
Go to solution Solved by emosun,
Coiled cables do not create any sort of issue in this fashion
Building a small home networking setup,聽wall mounting the gear and just wanted to check that this is okay for my (8port-PoE聽TP-link) switch power with the cable being reeled tightly like this, that it鈥檚 not going to cause any problems?聽
Thank you in advance 馃檪
Pretty sure its fine, nowhere near a sharp angle (where it might actually cause problems).
Used -700% storage
Looks like this will be fine. The only time I'd probably see an issue is long extension cables coiled up together that are pulling a lot of amperage.聽
PSU Tier List || Graphics Card Tier List|| CPU Cooler Tier List ||聽Community Standards
Resonance Cascade Specifications:聽
CPU: Intel i9-10980XE 18C/36T聽 ||CPU Cooler: Noctua NH-D15 Air Cooler聽||聽聽RAM: Corsair Vengeance LPX 64GB(8x8GB) DDR4-3600 CL18 ||聽聽Mobo: MSI X299聽Gaming Pro Carbon AC ||聽聽SSD: Samsung 970聽EVO聽1TB聽M.2-2280 Boot Drive/Some Games) 聽||聽聽HDD:2X Western Digital聽Caviar Blue 1TB(Game Drive) || 聽GPU: ASUS TUF Gaming RX 6900XT || 聽PSU: EVGA P2 1600W ||聽聽Case: Corsair 900D聽 ||聽聽Mouse: Logitech G502 Hero SE聽RGB ||聽聽Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky聽Switches|| 聽Mouse Pad: MAINGEAR ASSIST XL||聽聽Monitor:ASUS TUF Gaming VG34VQL1B 34"聽
