front panel usb Stiff USB 3.0 = no space for ventilation :(
30 minutes ago, gal-m said:Hey all,
I am building a PC in the Lian Li PC-O11 Dynamic case and have noticed that the stiff and rather large front panel USB 3.0 connector is preventing me from installing Corsair LL120 (intake) fans as seen on the picture below:
Does anyone have a solution or know where to buy a softer SMALLER USB 3.0 front panel extension cable in EUROPE?
I sincerely thank you all in advance
Either bend the cable a bit and route it over the fan like others have pointed our already,
or get a low profile extension cable:
Top end (on the picture above) goes into mobo, much les bulky than the standard cable.
https://www.amazon.com/ZRM-Standard-Expansion-Connector-Motherboard/dp/B08GF5PWKB/
