Dell monitor not working with ps4
Solved by dalekphalm,
2 hours ago, ZiyaadD said:
would this do the trick? It seems to do what your describing
I cannot guarantee whether that will work or not. It does not mention stripping HDCP from the signal.
But I have to ask, have you tried an HDMI - DVI cable? Cost is similar if not less than that box and should be more straight forward if it does work.
