NXZT AER RGB 2 Fans & RGB & Fan Controller Question
charles241
Hello,
I have 6 AER-RGB2 fans and 1 RGB & Fan controller. I am really confused going through the manuals and all and would appreciate answers from others.
In the RGB & Fan controller, there are 3 sockets for "FANS" and 2 sockets for "LEDS" (photo attached). Where do I plug my AER RGB fans to, in the FAN or LED socket? Also, is my one controller enough for my 6 fans?
Thank you in advance!
-Charles
Fans go into the FAN sockets and I think you can daisy chain fans if you dont have enough free slots on the controller (just search it up on yt or reddit)
