DT990 Pro or DT770 Pro?
Solved by Karim Bizid,
A good thing to think about is the devices on which you are going to use them.
If you are planning to use them often on mobile battery powered devices (laptops, phones) I wouldn't go for a headphone with a high resistance as 80 Ohms.
This simply drains the battery and doesn't go super loud.
I have worked on both quite often and there isn't a very big sound difference between the two.
Of course the 990 also has an open back. That makes it less suited for loud surroundings.
If you're not really an audiophile and you don't have an obvious reason for the 990 I would advice you to go for the 770.
